Rozwiertaki maszynowe DIN 206-A,B
Rozwiertaki ręczne stożkowe o zbieżności 1:50 z chwytem walcowym z zabierakiem kwadratowym według normy DIN 10. Narzędzia wykonane według normy DIN 206-A (kąt pochylenia link śrubowej - 0°) lub DIN 206-B (kąt pochylenia link śrubowej - 7°) ze stali szybkotnącej.
Produkt | D [mm] | l%1% [mm] | l [mm] | Długość L [mm] | Z | Rodzaj stali |
R0102-002-0090 | 50 | 174 | 127 | 347 | 12 | HSS |
R0102-002-0089 | 45 | 163 | 120 | 326 | 12 | HSS |
R0102-002-0088 | 44 | 163 | 120 | 326 | 12 | HSS |
R0102-002-0087 | 42 | 152 | 113 | 305 | 12 | HSS |
R0102-002-0086 | 40 | 152 | 113 | 305 | 12 | HSS |
R0102-002-0085 | 38 | 152 | 113 | 305 | 12 | HSS |
R0102-002-0084 | 36 | 142 | 104 | 284 | 12 | HSS |
R0102-002-0083 | 35 | 142 | 104 | 284 | 12 | HSS |
R0102-002-0082 | 34 | 142 | 104 | 284 | 12 | HSS |
R0102-002-0080 | 32 | 133 | 99 | 265 | 12 | HSS |
R0102-002-0079 | 30 | 124 | 88 | 247 | 10 | HSS |
R0102-002-0077 | 28 | 124 | 88 | 247 | 10 | HSS |
R0102-002-0076 | 27 | 124 | 88 | 247 | 10 | HSS |
R0102-002-0075 | 26 | 115 | 86 | 231 | 10 | HSS |
R0102-002-0074 | 25 | 115 | 86 | 231 | 10 | HSS |
R0102-002-0073 | 24 | 115 | 86 | 231 | 10 | HSS |
R0102-002-0072 | 23 | 107 | 78 | 215 | 10 | HSS |
R0102-002-0071 | 22 | 107 | 78 | 215 | 10 | HSS |
R0102-002-0070 | 21 | 100 | 74 | 201 | 10 | HSS |
R0102-002-0069 | 20 | 100 | 74 | 201 | 10 | HSS |
R0102-002-0068 | 19 | 93 | 69 | 188 | 10 | HSS |
R0102-002-0067 | 18 | 93 | 67 | 188 | 8 | HSS |
R0102-002-0066 | 17 | 87 | 60 | 175 | 8 | HSS |
R0102-002-0065 | 16 | 87 | 60 | 175 | 8 | HSS |
R0102-002-0064 | 15 | 81 | 58 | 163 | 8 | HSS |
R0102-002-0063 | 14 | 81 | 58 | 163 | 8 | HSS |
R0102-002-0062 | 13 | 76 | 56 | 152 | 8 | HSS |
R0102-002-0061 | 12 | 76 | 56 | 152 | 8 | HSS |
R0102-002-0060 | 11 | 71 | 51 | 142 | 8 | HSS |
R0102-002-0059 | 10 | 66 | 47 | 133 | 6 | HSS |
R0102-002-0058 | 9.5 | 62 | 42 | 124 | 6 | HSS |
R0102-002-0057 | 9 | 62 | 42 | 124 | 6 | HSS |
R0102-002-0056 | 8.5 | 58 | 37 | 115 | 6 | HSS |
R0102-002-0055 | 8 | 58 | 37 | 115 | 6 | HSS |
R0102-002-0054 | 7.5 | 54 | 39 | 107 | 6 | HSS |
R0102-002-0053 | 7 | 54 | 39 | 107 | 6 | HSS |
R0102-002-0052 | 6.5 | 50 | 36 | 100 | 6 | HSS |
R0102-002-0051 | 6 | 47 | 32 | 93 | 6 | HSS |
R0102-002-0050 | 5.5 | 47 | 32 | 93 | 6 | HSS |
R0102-002-0049 | 5 | 44 | 32 | 87 | 6 | HSS |
